Hi there,
this warning is pretty annoying on my side and takes up valuable screen real estate.
As soon as I move anything on the 2D document, it pops up.
Is there a way to remove it? Or get it to another position / size?
Solved by Cathy.Wang_Autodesk. Go to Solution.
Hi DNGK-A,
Thanks for you to point the issue out!
We will take a look this issue as soon as possible.
There is no good solution to close the banner now. The workaround is to close the PCB3d, then the banner will gone in PCB2d.
