Remove "The 2D and 3D PCB Documents are out of Sync" warning
D-NGK
D-NGK
Hi there,
this warning is pretty annoying on my side and takes up valuable screen real estate.
As soon as I move anything on the 2D document, it pops up.
Is there a way to remove it? Or get it to another position / size?
Cathy.Wang_Autodesk
Hi DNGK-A,
Thanks for you to point the issue out!
We will take a look this issue as soon as possible.
There is no good solution to close the banner now. The workaround is to close the PCB3d, then the banner will gone in PCB2d.
Cathy Wang
Software Engineer
Fusion 360 Team
Autodesk, Inc.
This method worked for me. One less nuisance... Thanks...
Hello Team,
any update on the 2D vs. 3D PCB out of sync management?
Why is the 3D not following the 2D PCB Layout the same way as the 2D PCB is following the schematic ?!?
BR, Joachim
jesper8W75R
The calculation of the 3D model is WAY too slow to update this in real-time.
And totally unnecessary.
