Fusion Electronics
Working an electronics project and need help with the schematic, the PCB, or making your components? Join the discussion as our community of electronic design specialists and industry experts provide you their insight and best practices.
Polygon filling isn't completed although having the same DRC rule.
1 REPLY 1
s_phamTESZU
106 Views, 1 Reply
Hi Autodesk Community,
I have two PCB board file with the exact same DRC, using the same components and board. However, I am trying to redesign the PCB and I am not sure why my polygon filling couldn't be the same as the previous board although I already change the DRC rule to the same as previous one.
Here's the screenshots of both boards:
You can see the 4 pin connector on the middle top, the polygon filling couldn't go through between the pins.You can see the 4 pin connector on the middle top, the polygon filling couldn't go through between the pins.You can see the 4 pin connector on the bottom, the copper filling went through between the pins.You can see the 4 pin connector on the bottom, the copper filling went through between the pins.
Maybe it just one setting thing to solve my issue, I couldn't really resolve it however. Appreciate if someone could let me know that! Thanks!
Kind regards,
Sean
1 REPLY 1
Evert_2N3055
in reply to: s_phamTESZU
Looks like the settings of the polygon are not the same. Think the isolate setting.
Not all the drc has influence on the polygon poor.
Right click on the polygon poor edge and compare the properties.
Technology Administrators
