Hi Autodesk Community,
I have two PCB board file with the exact same DRC, using the same components and board. However, I am trying to redesign the PCB and I am not sure why my polygon filling couldn't be the same as the previous board although I already change the DRC rule to the same as previous one.
Here's the screenshots of both boards:
Maybe it just one setting thing to solve my issue, I couldn't really resolve it however. Appreciate if someone could let me know that! Thanks!
Kind regards,
Sean
Solved by Evert_2N3055. Go to Solution.
Looks like the settings of the polygon are not the same. Think the isolate setting.
Not all the drc has influence on the polygon poor.
Right click on the polygon poor edge and compare the properties.
