Fusion Electronics
Working an electronics project and need help with the schematic, the PCB, or making your components? Join the discussion as our community of electronic design specialists and industry experts provide you their insight and best practices.
PCB supplier/manufacturer reports "that traces have a width of zero mils"
2 REPLIES 2
xpuipc
176 Views, 2 Replies
my pcb maker/supplier reports (again) that the traces of my PCB have a width of zero.
I am using the standard DRC rules of fusion except for the mask and the copper distance to outline.
In mask I put max to 2 mils (was 4 mils) that i get a soldermask bridge between the pins of 0.5 mm pitch.
And i changed the distance of copper to 20 (i think default is 40).
I am using the latest Fusion
I use traces of 6 mil width
In Fusion everything looks fine
Depending on the gerber viewer i can also see on my computer that the traces "are very thin", also some pads are not visible, see above.
Using a different online viewer it looks ok.
I think last time when my supplier reported this issue i tried things with the mask setting (min 2/max 4, or other way round...) and suddenly it was ok (trace width was OK), but not really know whats going on/what the parameters do...
So what can be the problem here...?
Thank you
Torsten
2 REPLIES 2
jorge_garcia
in reply to: xpuipc
Hi @xpuipc,
I hope you're doing well. It's interesting that using a different viewer the files look OK, that implies that the issue is with their internal viewer.
I would suggest taking a few screenshots of files in the other gerber viewer and sending it to them and see what they say. I'll ping the devs on this, but I have a strong feeling that the issue lies with the manufacturer.
Let me know if there's anything else I can do for you.
Best Regards,
Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
xpuipc
in reply to: jorge_garcia
Hi @jorge_garcia,
...it seems that my issue is the same issue like in this post (sorry did not see it before):
Traces are "very thin" => zero...i attached my gerber data... i am using the kicad gerber viewer....there you can see that the traces are very thin...
Torsten
Technology Administrators
