there's a problem with two polygon pours. See image below.
One polygon is +5V net, other one is +3.3V net.
There's no space between like it's between polygon and wire.
Thanks.
So, one polygon is +5V, other one is +3.3V, on same layer and overlapping. No space between polygons.
Solved by panpan_fan. Go to Solution.
Hi @silvio3105
You can set the rank for different polygon
Rank defines how polygons are subtracted from each other.
Polygons with a lower 'rank' appear "first" and thus get subtracted from polygons with a higher 'rank'.
Please have a try to see if it works for you.
Panpan Fan
Hi @silvio3105,
It's the nature of the beast, they will follow DRC and Netclass clearance values. Using the rank parameter you can define which one has priority in the filling process. If they have the same rank then they just short together, which generates a DRC error, but is also the easiest way to tie differently named reference planes together.
Best Regards,
