Image on Schematic sheet?
scott.nortman
Message 1 of 13
scott.nortman
How can you insert an image onto a schematic sheet, with either copy/paste or insert image?
Replies (12)
Message 2 of 13
everettac
There's a guide on SparkFun that explains the process from Eagle. Since Fusion 360 Electronics is basically Eagle, nothing should have changed except for where the buttons are placed. It also covers most of the different types of images that you would want to import.
Message 3 of 13
scott.nortman
Thanks for that info; I think I will need to to this for my PCB layout too.
But I was referring to the schematic; I want to place an image of a pinout on the schematic sheet and I can't see how to do that, thanks
Message 4 of 13
everettac
What type of file is the image that you would like to use?
Message 5 of 13
scott.nortman
Ideally a cut/paste image from the windows clip board, such as from Windows 10 'snip & sketch' but if that is not possible, any sort of saved image such as a BMP, JPG, or PNG
Message 6 of 13
everettac
With the current features available, going directly from your clipboard to the workspace is not possible, as all image solutions are implemented with shapes. The BMP and DXF methods in the guide at the link from my previous post will work for both schematic and board, while the SVG to Polygon will only work on boards. The BMP and DXF methods both convert the file into shapes within the workspace, with BMP creating squares with up to 32 different colors, and DXF creating lines and shapes on a layer of your choice. Any other filetype will need to be converted, although converting raster files to a suitable BMP file can be difficult if you are trying to use online utilities.
Message 7 of 13
scott.nortman
Thanks for the information.
Are there any plans to implement this feature?  Similar tools such as Altium and Kicad both allow for easy insertion of pictures into schematics.
Message 8 of 13
silvio3105
Any news about this feature?
Message 9 of 13
ruben.crispino
Still no news?
Message 10 of 13
dewilhiteR28PK
Community Visitor
Community Visitor
Still need this feature...
Message 11 of 13
jorge_garcia
Hi @dewilhiteR28PK,
I hope you're doing well. Thanks for the bump, I'll bump the existing request for this.
Let me know if there's anything else I can do for you.
Best Regards,
Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
Message 12 of 13
mace2769
Observer
Observer
Bumping this, I miss the ability to place images for reference in a schematic coming from Altium.
Message 13 of 13
jorge_garcia
Hello @mace2769,
Thanks for bumping the thread. There is still no change on this front yet. In the mean time you can still import a low color bitmap image (4-5 colors max) using the import-bmp-simple.ulp.
Best Regards,
Jorge Garcia
