How to change the CSV format on the BOM
Hi all,
I have exported a BOM in CSV format, but it's not right - how do I change the semicolons for comma's?
BTW, CSV means - Comma Separated Variable, not Semicolon Separated Variable.
Thanking you
PeterS
RichardHammerl
Hello @Anonymous ,
the bill of materials is created by a so-called User language program named bom.ulp.  It is a readable text file in C like syntax and can easily be changed. Please take a look at the bom.ulp attached.
I changed the separator from ;  to  ,  . It's in line 51.  😉
Here a screenshot:
Separator defines as semi colon in original bom.ulpSeparator defines as semi colon in original bom.ulp
Please copy the attached bom.ulp into your user ULP folder. This is in $home/Documents/Fusion 360/ulps .
I hope this helps.
Richard Hammerl
Thank you for your reply Richard.
That worked.
Thank you
PeterS
