Hi @fahad.bhatti,
It seems like at some point multiple instances of the Fusion team library were created. You will have to check them out individually to see which one is the latest.
Does your data panel show the duplication of those libraries?
Once you know which option is the latest and most up to date then you can use the Swap libraries and update functionalities to have your designs reference the latest version.
Once that's done delete the duplicates.
Let me know if there's anything else I can do for you.
Best Regards,
Jorge Garcia
Product Support Specialist for Fusion 360 and EAGLE
