Fusion Electronics
Working an electronics project and need help with the schematic, the PCB, or making your components? Join the discussion as our community of electronic design specialists and industry experts provide you their insight and best practices.
How to Increase the Thickness of Traces
1 REPLY 1
mohdyaser3
373 Views, 1 Reply
mohdyaser3
I have a 5 A current carrying trace, according to calculations the trace should be 2.5 mm which is very big for my PCB. how can I increase the thickness of traces (oz/ft^2) so I can reduce the width to a reasonable size.
Labels (3)
1 REPLY 1
Pieter.Jan.Van.de.Maele
You can specify the thickness for each layer in the "Layer Stack Manager" which is available in the "DRC" dialog under the Rules DRC/ERC section in the toolbar. You can select from a set of available materials from the manufacturer or specify your own by checking the "edit material properties" checkbox. Make sure though that whatever you specify is actually available with the manufacturer you are working with.
Pieter-Jan Van de Maele
Senior Engineering Manager, Fusion Electronics
