Fusion Electronics
Working an electronics project and need help with the schematic, the PCB, or making your components? Join the discussion as our community of electronic design specialists and industry experts provide you their insight and best practices.
newbie - struggling to create custom symbol
4 REPLIES 4
Mark532011
228 Views, 4 Replies
I am trying to find some documentation on how to get a custom symbol usable. The online docs (Autodesk Doc link ) help with the actual creation of the symbol - such as adding the pins and swaplevels, etc. and that is reasonably straightforward but I cannot find anything on what is next.
I created a symbol, but I can't use it in a schematic as it doesn't have a footprint.
so I created a footprint but I don't know to link them and make it usable.
The online docs I can find seem to only give me part of the process, is there anything that gives a better overview of the whole thing?
4 REPLIES 4
Hello @Mark532011 ,
you can find a realy good documentation when you download the Eagle-Installation-File and take a look in the Installation-Subfolder "doc":
In chapter 8, page 261, in "manual_en.pdf" you can find a lot of hints how to make your own devices.
You can define symbols without footprint.
In schematic you add a "device", that minimum contains a symbol.
Have you only created a symbol?
Eagle 9.6.2 / Fusion 360
Working with Eagle since Version 3.x
jorge_garcia2
in reply to: Mark532011
Hi @Mark532011,
 I hope you're doing well. What you are missing is to create a Component (formerly called Device) that links the schematic and footprint together.
I made a video series that goes through the whole process of making library parts.
(416) Create your own electronics parts in Fusion 360: Video 1 Electronics Libraries Overview - YouT...
Let me know if there's anything else I can do for you.
Best Regards,
Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
Mark532011
Thanks for the help guys:
jorge.garcia- yours was the first set of videos I found while researching. While they cover the libraries and creation of symbols quite well, there needs to be a part 3 that explains footprints, components and packages and how to put the pieces together to make a usable symbol or component, i.e. something that can be dragged onto a schematic. What the difference between a component and a package is, how the connections between them work (I still don't know why G$1,P$1 needs to be connected as well as G$1.P$2)
m.neujahr_at_moe - thanks for the info. It helped a little but the different terminology and UI of the EAGLE thing made it pretty tough to puzzle out what to do.
I am happy to report that after several hours of work, I have successfully got a custom symbol to appear on a schematic. In typically Fusion360 fashion it is about as byzantine of a process as can be imagined using multiple different techniques to link the various pieces together...sigh, but at least it works.
Mark532011
my mistake. I see there is a part 3,4,5 in the series. For some reason it doesn't show up in the list of videos on the side. I will view them - thanks for doing it.
