I want to place two components at the same position but the router don't allow that cause of the pad overlapping.
How to disable DRC live verification/blocking ?
I set all DRC rules to "0", still the same problem, I can't place where I want.
DRC setting said with 0 the rule is disabled but seem not working.
Eliott.
Solved by jorge_garcia. Go to Solution.
Hello @eliott_trotebas,
I hope you're doing well. Go near the bottom of the screen you'll find a toolbar, on the far right of that bar you'll see the violator modes. Set it to Ignore violators. That will allow you to place the component wherever you want.
Let me know if there's anything else I can do for you.
Best Regards,
Thank you for you fast answer.
That exactly what I was looking for.
Have a good day.
Eliott Trotebas.
