Fusion Electronics
Working an electronics project and need help with the schematic, the PCB, or making your components? Join the discussion as our community of electronic design specialists and industry experts provide you their insight and best practices.
How are copper pours connected to other layers?
2 REPLIES 2
yaqoubdesign
250 Views, 2 Replies
If I add a copper pour on my top layer (bottom layer is DGND),  and give it the same signal name (DGND):
1)  How does this  copper pour connect  to the DGND layer? I assume some kind of default via with some default spacing?
2)  If I want this copper to be exposed (no solder mask),  do I have to add a tstop polygon to the pour area?
2 REPLIES 2
mtl_asm
in reply to: yaqoubdesign
1) you have to add the via yourself. simply naming the pour will not automatically generated any physical connection. place a via then name it the same signal as the pour and it should connect to the 2 planes on each layer.
2) yes that should work.
yaqoubdesign
Thank you..
Technology Administrators
