I created new electronic libraries with 3D models that have colors applied to them. When you generate a 3D PCB, everything looks fine, but after closing 3D PCB tab and opening it again, colors are messed up.
You can create new electronic library with a random 3D model even without applying any colors to it, just using default color and it still shows other color. 3D model for a electronic library can be linked or not, it doesnt matter.
If I recall correctly, everything was working fine before some of the updates and after some two or three updates, I noticed these problems with colors. I created new libraries with new 3D models, created new electronic designs and generated new 3D PCB, everything was fine, but in one or another way, making changes to a PCB still messes up the colors. I was able to reproduce this bug on Windows and OS X. (also OS X version is crashing like hell in Fusion Electronics)
So, questions as follow:
Solved by yqliu. Go to Solution.
Hello @Edgaras.Janušauskas ,
I can not reproduce this issue. Can you share your 3d package document to me?
Hi @yqliu,
thanks for the replay.
I can not attach library file, only 3D package. (The file type (.flbr) is not supported.)
In order to reproduce the problem follow these steps:
3D model colors are changed and there a new colors assign to it.
Hi @Edgaras.Janušauskas ,
I can reproduce the issue with the file you shared with me. I have created a ticket to track this issue. Thanks again for reporting the bug and sharing your file.
Hi this does not happen 3D model dependent, It happens randomly. I am also having same problems with some of my designs and this only occurs with 3D models of electronics not completly fusion 360 related.
Here is my post about it.
https://forums.autodesk.com/t5/fusion-360-electronics/linked-3d-pcb-shows-wrong-colors-sometimes-on-...
Also if you check recent topics there are few other people complaning about this.
I would recomend that you try updates on PCB few times and maybe link it to another file and update. That way it may occur because as I said it happens randomly.
Here is another topic about it.
https://forums.autodesk.com/t5/fusion-360-electronics/components-in-3d-pcb-showing-up-as-red/td-p/97...
Hopefully you can reproduce it and gets a fix very soon.
