Hi There,
I have problem and need your help who knows much better than me.
When download some component from snapeda first opening as a 3d model on my screen.
Kind of that and i push save in my library. It is perfectly saving in my library with schematic model pcb model but 3d model never shows up. When i try to push 3d model first saying missing model kind of that.
That i am really sure i saved model in my library but unfortunately not seeing on my screen when i push.
If someone know how to fix this problem i will be really happy....
Solved by jorge_garcia. Go to Solution.
Hello @mirac_soykose,
I hope you're doing well. Make sure that you go into the schematic and do an update so that the latest version of your library is used in the design. If the model is in fact in the library then doing an update should solve this.
You can do this by going into the library menu in the schematic, you'll find the library update command there.
Let me know if there's anything else I can do for you.
Best Regards,
