- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Fusion 360 is working well and meets acceptable performance expectations as far as responsiveness except for the electronics portion.
On creating a new electronics design, the software still functions, however, when opening even a fresh schematic, the software lags and hangs, but not frozen, for around 45 seconds to fully load. The load time would seem excessive for a 2d app, although not intolerable if that was the limit. The schematic applet hangs for around 30 seconds with every click like it's reindexing or calling for something and facing a timeout. The software is still partially "responsive" but not immediately during the lag event. At no time does the software "crash", it simply compounds and becomes slower with every attempt to affect a control article. The only way to get it back to a usable state is to select a different type of tab or close the current electrical design tab.
Steps were reactivly taken to correct the issue:
* Ensured all component libraries are updated
* Disabled all component libraries
* Verified system readiness and responsiveness.
* Checked for pending updates and syncs within F360
* Cleared F360 cache from within the help menu
* Reset F360 from the repair menu
* Ran F360 repair install from the repair menu
* Searched Google for issues related to Slowness and Lag in electronics design mode
* Searched Autodesk forum for preliminary solutions with non-similar slowness problems being commonly reported.
This problem is potentially isolated to a specific issue within this computer-software configuration.
PS: About a month ago, the software suite was completely reinstalled after manual removal due to a catastrophic failure caused by the Fusion 360 update failing to install. Even the repair tool was corrupted and was unable to repair or uninstall successfully.
The application was completely removed, minus most registry entries, and reinstalled after a cache/temp dump.
I did not post a video as it is likely no benefit in watching normal Fusion 360 electronics play out in obscenely slow motion. If you feel it would be beneficial to observe, please note and I will comply.
Remote desktop and diagnostic logs are available to Autodesk on request.
Thank you for your time in reading and any suggestions you may be able to offer.
EDIT:
PC specifications:
Device name DESKTOP-8******
Processor Intel(R) Core(TM) i3-4170T CPU @ 3.20GHz 3.20 GHz
Installed RAM 16.0 GB
System type 64-bit operating system, x64-based processor
Pen and touch No pen or touch input is available for this display
Edition Windows 10 Pro
Version 22H2
Installed on 7/24/2022
OS build 19045.2846
Experience Windows Feature Experience Pack 120.2212.4190.0
