I'm right at the extent of my knowledge here....but here goes.
If I understand correctly the ULP generates Gcode (with a tool diameter allowance) around the periphery of a trace. Once that has been completed the
trace and the width of cut are added together to form a new somewhat larger shape. The process repeats, namely the ULP generates Gcode around the periphery of this new and larger trace. This is repeated as many times as in necessary to achieve the desired isolation. Thus the total tool path is generated sequentially with each pass being just that little further (the tool width) away from the original trace.
Again it is my understanding that the POUR function is critical to the ULP 's function.
As I have described I use the ULP regularly, and thus I have to export a Fusion Electronics board into EAGLE so that I can use the ULP. I have had no real difficulty
in exporting a Fusion generated board into EAGLE which leads me to believe that whatever Autodesk did in porting EAGLE into Fusion was not a huge change but sufficient that the ULP would no longer work.
It would be a major time saver to be able to use the ULP from within Fusion WITHOUT the need to export it to EAGLE......and even more importantly Autodesk have indicated that they wish to end all support for EAGLE altogether in a years time. In that case I need an alternative.
Have you tried generating tool paths (for PCB isolation routing)from within Fusion using the regular Contour and Adaptive methods? I have and had very little success and extremely time consuming. Maybe there is a better way or workflow that would achieve an acceptable result.....but this is the frustrating part.......the ULP within EAGLE already did that seamlessly, no need for some specialist workaround!
Craig
