My mouse works perfect when other workspaces like cad, cam, sheet but in electronics i can't zoom with my mouse it goes up and down when i use my scroll wheel.
My mouse is mx master 3 and i am on 16" MacBook Pro (MacOS 10.15.7).
Solved by RichardHammerl. Go to Solution.
Hi @bora2002md ,
I don't have a mx master 3 to confirm the issue at this moment. But we will look at it.
Richard
I tried with different mouse (Logitech G300) and it works fine. Maybe its about Logitech options app? But i will be very happy if Autodesk devs can fix it. Another weird think i found I can't pan infinite with trackpad it limits me to the component area.
Hi @bora2002md
could you please check the Preferences for Electronics (click you profile icon, then Preferences)?
What is the setting for legacy mouse wheel mode and what if you change it?
Hope this helps.
I know it is a little late, but if you still want to use the vertical pan capability, turn off the legacy mouse support. Now you have the vertical pan. To Zoom in and out just press the vertical scroll wheel down while scrolling. No you have everything as it should be.
This does not work for me using an Apple Mighty Mouse (the one with the 2D scroll ball). If legacy is turned off, it just pans, which I want. But clicking and scrolling does not zoom. I'd sure like to be able to just hold a meta key while scrolling to zoom.
