Announcements
Starting in December, we will archive content from the community that is 10 years and older. This FAQ provides more information.
GND pour not rendering correctly in 3D view
p.schauerB47B7
p.schauerB47B7
Have a simple two layer board with a GND pour on both sides. This pour used to render correctly on both the top and bottom (up until a specific version of the file). Recent versions of the file no longer render the upper layer at all with a "unclose" error (see attached). I cannot share the file itself (proprietary design), but would like some advice on what to look for to rectify this issue.
It may be of note that the PCBs are correctly manufactured - the upper ground pour is only missing from the 3D view.
panpan_fan
Hi @p.schauerB47B7
Thanks for reporting this issue.
Unfortunately I can't reproduce this issue easily.
Would you mind trying the following text command and sharing the text file to us?
That would be very helpful.
You can follow the steps below:
1. Show text command
2. Text command: electron.boardinfo output_file_name. Like:
3. Find the text file and send it to us
I will send my email address to you as a private message
Panpan Fan
p.schauerB47B7
Thanks Panpan_fan. The text file has been sent to you via email.
