Fusion Electronics
Working an electronics project and need help with the schematic, the PCB, or making your components? Join the discussion as our community of electronic design specialists and industry experts provide you their insight and best practices.
Cannot route traces to Tag-Connect pads
2 REPLIES 2
dresselhaus.dan
156 Views, 2 Replies
Whenever I attempt to route my trace to the SMD pads on my Tag-Connect footprint I get a yellow semi-circle blocking me.  I do not see any keepouts or other barriers.  Is there a DRC setting that is causing this?
2 REPLIES 2
Hi there- yes it most likely is a DRC setting. By default "Push Violators" stops you from routing with a DRC violation. You can allow routing with violators which can be helpful to see what exactly is going on:
Pieter-Jan Van de Maele
Senior Engineering Manager, Fusion Electronics
I was able to connect to my tag-connect pads after I disabled the DRC for copper/ board outline clearance.
Technology Administrators
