Whenever I attempt to route my trace to the SMD pads on my Tag-Connect footprint I get a yellow semi-circle blocking me. I do not see any keepouts or other barriers. Is there a DRC setting that is causing this?
Solved by dresselhaus.dan. Go to Solution.
Hi there- yes it most likely is a DRC setting. By default "Push Violators" stops you from routing with a DRC violation. You can allow routing with violators which can be helpful to see what exactly is going on:
I was able to connect to my tag-connect pads after I disabled the DRC for copper/ board outline clearance.
