Is or will there be a cable and harness tool for Fusion 360? I can create lofts but ideally I'd like something that can be used to generate wiring diagrams as well. Is Inventor best if our designs mostly include electronics and wiring together?
Ed
Solved by ed_waugh. Go to Solution.
Hi @ed_waugh
currently there is no such tool available in Fusion 360. There are thoughts about having this extra functionality, but I do not know about fixed planes or timelines at the moment. IMHO it would be extremely helpful and great to have all the wiring/cables/harness stuff in Fusion.
From some reading it looks like the answer is to use Inventor if you want to do this type of work. Fusion should be for small projects where the parts are 3D printed and/or generatively designed.
@ed_waugh wrote:From some reading it looks like the answer is to use Inventor if you want to do this type of work. Fusion should be for small projects where the parts are 3D printed and/or generatively designed.
I would totally disagree. The whole point of Fusion is to be an integrated environment for product design (among other things). It has mechanical design, visual rendering, simulation, manufacturing, and now PCBs. Cabling and wiring diagrams are just as important as the other elements.
C|
If wire harnesses with wiring diagrams were implemented it would be an absolute dream come true! I'd never look at another CAD program ever again!
Absolutely agree, we need harness building!
the whole car and motorsport community is waiting for it!
YES, I think this is ESSENTIAL now that 3D Modeling and PCB design are integrated!
I wish that all the time and effort that went into other non-important features like 3D Slicing/printing , went into more needed features!
Bring it on!
I completley agree, the wiring diagram is really a missing basic function....
Any updates to this topic?
Can somone from the Fusion 360 respond, if wiring harness design is already in the roadmap?
I think this is really a big part missing, making Fusion 360 to a allaround solution to go. Near every machine nowadays needs some form of cable assemblies.
Unfortunately, there are no current projects underway to support wire harness design in Fusion. I agree that this is a needed addition, but, as you probably know, there are lots of "if only Fusion had X" additions that are needed. We're moving as fast as we can... This one is near to my heart, because in a past life, I worked on a wire harness design tool myself. There is an opportunity here for some enterprising add-in developer to use the Fusion API to implement an add-in to fill this gap. If only there were 48 hours in a day. 😀
hi
Any updates regarding harness design? Has it been considered in the meantime?
2024 and we are still waiting for this, wiring harness design and drafting tool.
Hi @Giridhar_Raju ,
I hope you're doing well. Thanks for the bump, for now there are no immediate plans to implement this. If you need the wiring harness functionality right now, this is currently available in AutoCAD Electrical.
Let me know if there's anything else I can do for you.
Best Regards,
