The fastest method of creating buses?
_Marek
_Marek
For now, if I want to create a bus, I had to create first routes stubs with names, then create bus outside of them, next go to properties of bus in order to add signals and finally route stubs to bus. I would expect if I draw new bus which crossing many signals, all of them will became part of the bus.
Also if I create new signal from eg. MCU to the bus, I would expect that this signal will be automatically added to that bus with desired names. Of course appropriate dialog box should appear.
Is it possible to achieve such a behavior?
jorge_garcia
Hi @_Marek ,
I hope you're doing well. So this is not how busses work, so this behavior isn't possible at all right now. I refer you to this page for information on how the bus command is intended to work.
https://help.autodesk.com/view/fusion360/ENU/?guid=ECD-CLI-B#bus
Let me know if there's anything else I can do for you.
Best Regards,
Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
