I have uploaded an Eagle project to Fusion to make some update.
The dimension are about 230mm x 145mm, in four layers.
On each modification (routing, moving a track or a components,...) it seems that Fusion make a well know Eagle funciton RATSNEST.
My issue is that RATSNESTtake 2-3 seconds on this board.
Are there any way to remove the automatic RATSNEST?
Thanks for any Answer,
Bernard
Hi, @Anonymous
Electronics for Fusion has introduced new "Push Violators" and "Walkaround Violators" mode, a "RATNEST" would be executed every time after updating PCB under these two modes. You are right. These two functions are newly introduced, you can see wires are pushed away or walked around devices automatically when dragging to move or route the wires.
If you want to keep legacy behavior, simply adjust the Violation mode to "Ignore Violators" in the navigation bar.
Hope that helps~
-Yiqiu
