Fusion Electronics
Working an electronics project and need help with the schematic, the PCB, or making your components? Join the discussion as our community of electronic design specialists and industry experts provide you their insight and best practices.
All the colors changed
10 REPLIES 10
Message 1 of 11
robmacklin
916 Views, 10 Replies
I'm using the Electronics editor.  Yesterday I received the latest update to version 2.0.10244.  Today when I opened my file all the colors in the schematic editor have changed.  Previously components where red, nets where green, I had a high contrast option setup so it was easy to see selections.  Today everything is pastel colors, light purples, oranges, and almost no visible change when selecting objects.  How can I restore the original colors?
UPDATE:  The Highlight options in the Preferences section General->Electronics->Colors does not seem to work any more.  I select various high contrast, light, or dark options and I see no visible change in the behavior of the editor.
10 REPLIES 10
Message 2 of 11
panpan_fan
in reply to: robmacklin
Hi @robmacklin
I hope you are doing well!
I can reproduce the high contrast issue and I will reported it to our develop team.
I will keep you updated when we fix it. Sorry again for all inconveniences.
Panpan Fan
Message 3 of 11
panpan_fan
in reply to: panpan_fan
Hi @robmacklin
Would you mind confirming if you always check the high contrast checkbox before?
If you don't mind, please attach a screenshot of your schematic so that we can check the layer color for you.
Thanks a lot!
Panpan Fan
Message 4 of 11
robmacklin
I enabled the High Contrast setting a few weeks ago and have been using it since.  It was enabled when the update was applied yesterday.
Here's a screen shot of my schematic.  It is now orange and teal instead of red and green.
Another Fusion user in my company also sees the new colors in the electronic editor, so this does not appear to be a local problem with my installation.
Message 5 of 11
jorge_garcia
Hi @robmacklin ,
I hope you're doing well. These are now the default colors in Electronics if you click on the Script function you can run the older color scheme. Let me know this gives you any problems.
Best Regards,
Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
Message 6 of 11
bboyceCXAW4
in reply to: jorge_garcia
I'm sorry @jorge_garcia, I don't know what you mean by " click on the Script function".
I often use the Show tool to help me locate parts and nets from the schematic, on the PCB layout.  And visa-versa.
Since the update, I cannot find a setting that significantly highlights anything on the schematic.  The PCB highlights are not much better.   I can see why it was changed, because in the old system it was hard to find a setting that made everything work reasonably well.  But this new system is even more frustrating.
I have spent a lot of time trying to find a set of color and highlight settings that is optimal (that's being nice, a better word would be workable).  I keep telling myself that there is a good set, and when you find it, it will have been worth the time searching.
I'm still searching.  If you're happy(@members) please put a screen shot up of your preferences.
Message 7 of 11
panpan_fan
in reply to: bboyceCXAW4
Hi @bboyceCXAW4
The highlight issue has been reported to the develop team and will be fixed as soon as possible.
I will keep you updated when we release the fix for this issue.
Besides, would you mind trying change the layer color to see if the highlight will be better? Hope it can help.
Panpan Fan
Message 8 of 11
bboyceCXAW4
@panpan_fan ,
Thank you.  That does the trick!  I changed Top to a deep red, and the Nets to a rich purple.  Then Highlight goes Pepto-Bismal pink for Top and sky blue to rich purple for the Bottom.  Nets are now going from purple to bright green.   All this works on my usual white background.
I didn't take time to tune up the black background.
Thank you for the work around, I'm much happier and more productive.
Good health,
bboyceCXAW4
Message 9 of 11
panpan_fan
Hi @robmacklin  @bboyceCXAW4
Today we release Fusion 360 V2.0.10356 and the highlight issue is fixed now.
Please have a try, thanks!
Panpan Fan
Message 10 of 11
m_walczak
Doesn't appear to be fixed for me.
Message 11 of 11
panpan_fan
in reply to: m_walczak
Hi @m_walczak
Sorry to hear that you still have the problem.
Would you mind describing more and attaching some screenshots to show your problem?
In this way, we can find out the reason for your problem.
Panpan Fan
