Fusion Electronics
Working an electronics project and need help with the schematic, the PCB, or making your components? Join the discussion as our community of electronic design specialists and industry experts provide you their insight and best practices.
i have problem of Fusion 360 pcb
1 REPLY 1
chipashvili
104 Views, 1 Reply
hello everyone, i am working a very simple pcb design of my project.
but i cant do very easy things.  Cant connect lines.
there is the video of my problem . ..
1 REPLY 1
jorge_garcia2
in reply to: chipashvili
Hi @chipashvili ,
I hope you're doing well. It looks like you are trying to just work straight from there board. In the schematic it's important that you define the connections so that you have airwires on the board to route.
If you must work only on the board then you'll have to use the SIGNAL command to define the connections and then use the route command to convert the airwires.
Let me know if there's anything else I can do for you.
Best Regards,
Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
