Fusion Electronics
Working an electronics project and need help with the schematic, the PCB, or making your components? Join the discussion as our community of electronic design specialists and industry experts provide you their insight and best practices.
Add graphics to the PCB
10 REPLIES 10
Message 1 of 11
CaptainMJ
6987 Views, 10 Replies
Hi All!
Just curious to know if there is a away to add graphics to the PCB board? I know there are circle and text options etc, but could i paste or import an image I have from an other program? For example a Adobe Illustrator Vector or jpeg/png or something similar?
Just want to add my company logo to the board but haven't been able to figure out how.
Best Regards,
Marcus
10 REPLIES 10
Message 2 of 11
jorge_garcia
in reply to: CaptainMJ
Hi @CaptainMJ,
I hope you're doing well. You can import a bitmap into FusionElectronics, you have to use the import-bmp.ulp that comes with Fusion360 Electronics. Click on the Automate menu and then select the run ULP option (it's the orange one). In the dialog that pops up look for import-bmp.ulp.
Couple of things when using this:
-It works best with a monochrome bitmap. The file should be saved as such it's not enough to say the file is only black and white, because you can get a lot of gradients and each one of those needs a separate layer on the PCB.
-You have to choose the sizing of the log at the time of import and you won't be able to scale it afterwards.
Let me know if you have any questions about this.
Best Regards,
Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
Message 3 of 11
CaptainMJ
in reply to: jorge_garcia
Hi Jorge,
Thanks, i managed to do it following your instructions, but i now have a few images on layer 200, I dont seem to be able to move or delete them except for piece by piece. Is there away to delete the entire layer 200 so i can start again? And once i got the bitmap in correct size, how am i able to move it? I am not able to do it using the select tool as it selects items on all layers,or is there a way to use it to select items on only a specific layer?
Marcus
Best Regards,
Marcus
Message 4 of 11
jorge_garcia
Hi @CaptainMJ,
I hope you're doing well. Use the selection filter to limit the selection to layer 200, from there you'll be able to select it and delete. You would do something similar when you want to move it, the only difference would be that you would use Move instead of delete.
Let me know if there's anything else I can do for you.
Best Regards,
Jorge Garcia
Message 5 of 11
CaptainMJ
@jorge_garcia Many thanks for the help, this resolved it!
Best Regards,
Marcus
Message 6 of 11
AntonGabrie
Polygon cutouts on silk layer are a must!!!!! Bit map images are low quality, and rendering in high detail makes fusion super slow. Polygons are now available in silkscreen, please make the polygon cutouts possible!!!
Message 7 of 11
Once I have imported and placed my bitmap why does it not show in the other views (images of board in the "common" tab, or 360's 3D view of the linked project)
Message 8 of 11
jimUR4RG
I would like to know this too. It's hard to estimate if a graphic looks good without seeing it in the 3D view.
Message 9 of 11
Wouldn't it be cool if we could import more than BMP files? I mean its 2022 after all I think BMP files were of limited use even back in 1999.
So maybe Autodesk should offer us an import option for SVGs?
Message 10 of 11
a_tekautz
in reply to: t.bryantSM4ZS
Hi!
At least there is a ULP called "DXFimport V2.0" that is able to import 2D DXF. You have to specify layer, position and scale on importing. Position and layer can be changed later, so can it be rotated (at least in steps of 90°). I was not able to resize it other than during the import process.
Maybe this helps.
Best,
Andreas
Message 11 of 11
zachalewel
This might not be the most helpful, but it's super easy to add SVG graphics to my boards via Fusion 360's 3D design space as it supports SVGs by default. FWIW I make my own boards using subtractive manufacturing on FR4 with a longmill CNC. With a properly designed fixture, it's good for about 10 mil traces and gives ya two sides (vias but no micro-vias).
Just want to give a quick thank you to @jorge.garcia. You, good sir have helped me a ton!
Technology Administrators
