Fusion Electronics
Working an electronics project and need help with the schematic, the PCB, or making your components? Join the discussion as our community of electronic design specialists and industry experts provide you their insight and best practices.
Add Existing Design to New Design?
2 REPLIES 2
crgmakes
288 Views, 2 Replies
Hello everyone. I have a number of pre-built modules that I need to combine into one design and create a single PCB mother board for. I have the schematics and PCB boards for each of the modules and I want to "import" them into a single design so I can accurately represent the physics layout of the modules on the mother board. In "regular" Fusion I would just say "insert in to current design", but electronics does not seem to have that ability. I tried to explore "referencing" the designs, but I seem to be limited to a single reference.
Is there any way to reference a number of other designs in a project? Or is there some way to turn the pre-existing designs into a new template or design block or something?
The way Autodesk has integrated Eagle into the Fusion ecosphere is completely non-sensical to me.
Any suggestions?
-Tom
2 REPLIES 2
jorge_garcia
in reply to: crgmakes
Hello @crgmakes,
I hope you're doing well. In the PLace menu, you'll see the option to Insert Electronic Design. The design as inserted does not maintain a reference to the original design, it's a copy. That should cover what you need though.
Let me know if there's anything else I can do for you.
Best Regards,
Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
Kudos are much appreciated if the information I have shared is helpful to you and/or others.
crgmakes
in reply to: jorge_garcia
Thanks Jorge - I stumbled across your solution about 5 mins after I posted. Thanks for the feedback!
-Tom
