How to add custom schematic sheet template
akshay_naikwade
akshay_naikwade
Hello Fusion,
I want to know that is there any command or way to add/create custom schematic sheet template .
Thanks.
Yuvraj W.
graemejthomson
Hi, not 100% this answer is for what you are asking, but custom schematic frames (sheets with drawing number, title etc) can be made and edited as a component. This is then dragged into your schematic design.
jorge_garcia
Hi @graemejthomson ,
I hope you're doing well. Just to add to this thread, you can see examples of this in the frame library. Go into your library manager in Fusion and look for frames and make sure that library is enabled.
Let me know if there's anything else I can do for you.
Best Regards,
Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
