Using Multi-part Component across different sheets
deepak_elango
Message 1 of 9
deepak_elango
Hello Everyone,
 I have some doubts about multipart components.
I want to access my multipart component across different sheets and I want it to be referenced as single package when converting to PCB
Can anyone suggest way to do this?
Is there any forums post or document which can be referenced for understanding everything about Modules?
Replies (8)
Message 2 of 9
RichardHammerl
Hi @deepak_elango
there are library components defined that consist of several symbols. These so-called gates can be placed individually (depending on the Addlevel set in the Component Editor) in the schematic. They can be distributed over several sheets.
So, please use the Place Component panel to add the first gate of a component. As long as you stay on the same schematic sheet you can add one gate after the other.
As soon as you go to another sheet in the schematic, you have to use the so-called INVOKE command which is accessible in the Design / Modify menu.
Activate the command and type the component's name in the command line (or click on one gate of the component in case there is already one placed).  A menu will show up now that allows to select non-used gates of the component.
I hope this helps.
Best regards,
Richard Hammerl
Message 3 of 9
deepak_elango
This is working for sheet's but when I try to Invoke a component inside a Module it was not accessible
Message 4 of 9
jorge_garcia
Hello @deepak_elango,
I hope you're doing well. You can't split components across modules, this is a limitation of the hierarchy implementation.
Let me know if there's anything else I can do for you.
Best Regards,
​Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
Kudos are much appreciated if the information I have shared is helpful to you and/or others.
Message 5 of 9
yaprakcierailesi
I couldn't get it to work. As far as I understand, I tried to do what you said, but it didn't work. I have placed 3 components of a 4 component part on one sheet, and then I run the invoke command on another sheet, but it does not see the part on sheet 1. I think I am doing something wrong.
Message 6 of 9
jorge_garcia
Hello @yaprakcierailesi ,
You have to run invoke on the same sheet where you have the 3 components. Click one of the components a small dialog will pop up allowing you to select the missing component and bring it into the current sheet. Once it's in the current sheet you can move it to whatever sheet you want.
Best Regards,
​Jorge Garcia
Message 7 of 9
yaprakcierailesi
Thanks for the help. I have one question left. "Once it's in the current sheet, you can move it to whatever sheet you want." Do I need to cut and paste the part for moving to another sheet?
Message 8 of 9
jorge_garcia
Hello @yaprakcierailesi,
I hope you're doing well. No, don't do cut and paste. You do a group Move, you are moving from one sheet to the another. If you do a cut and paste you'll be deleting an instance and then inserting a new one which is not what you want to do.
Best Regards,
​Jorge Garcia
Message 9 of 9
yaprakcierailesi
I am grateful for your time. I have successfully transferred the parts to different sheets.
