I initially created a component (switch) with a prefix of S.
I placed the switch in my design. The reference designator was S1.
I realized that the prefix was not in line with our library standards.
I changed the prefix in the library component to SW, saved the library.
In the design, I did an update all libraries. All attributes changed for the switch except the reference designator.
Next I tried replace part, still reference designator would not update to the SW prefix.
I placed a new instance of the component in the schematic and that instance had the SW prefix (SW1).
I ended up changing the first instance manually in the part properties because I didn't want to delete it and place a new instance since it had already been routed.
Anyone else seen this? Am I doing something wrong? Is there another way to do it? Is it a bug?
My fusion version
Thanks for all you do. Keep up the good work.
