- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
For some reason the normal detection that runs all the time for 2D pcb catches most things but it seems that I have to specifically run a DRC check from the menu for it to then all at once detect what may be a great many little stubs. Why does it not seem to check for stubs in the normal run-all-the-time DRC check? This may be a feature to prevent loading or something?
Part 2: I am removing part 2 because I found right click then use 'Select' allows finding other traces such as a tiny trace that I was having trouble removing this tiny stub that was smaller than another same layer trace.
As always, thank you for your assist on this forum.
