Setting Component Colors via User Defined Parameters
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I am creating 3D Models of various electronic components for export to our Mechanical Engineering group's CAD package(s). One group of these components are the classic axial leaded, through hole resistors. These are available in various power ratings (physical sizes) and tolerances. there are several colored bands (axially symmetric about the body of the resistor) from which the user can read the values and tolerance for a given component. I really don't want to create a bunch of unique valued / sized models each design.
I would much rather be able to apply a single model (for a given power rating) and then go the parameter section JUST FOR THAT COMPONENT, and put type in a single number (0 - 9) which maps to a predefined color for each band. How can I implement this? Also, It would necessary to be able to select a specific component to apply these selection values to as I do not wish to enter a value for one color band, and all the resistors in the design change that band to the same color.
Thank You for Your Input and Assistance.
BruceM
