Report; gerber export, decimal separator issue
PinRudolf
Message 1 of 8
PinRudolf
On gerber viewers from pcbWay, jlcPCB and Ucamco the annular rings and line widths did not match my Fusion model.
They showed up like this:
But were designed like this:
I've read on the forum that people were having trouble with the Polygon command when using a comma as decimal separator and indeed, that was the issue here as well. Though unlike the polygon issue this one has not been fixed with the last update.
Obviously switching my Windows settings is a workaround but I did just order some PCB's with silly through hole pads before I noticed this error. 😉
Just wanted to make sure Autodesk is aware of this!
(And if you fix it, could you nudge the Revit MEP team to fix their comma separator errors as well, they have been on it for years!) 😉
Replies (7)
Message 2 of 8
jorge_garcia
Hi @PinRudolf ,
I hope you're doing well. Are you aware of the environment variable the corrects this so that you don't have to switch your Windows settings? Here it is for your info:
Environment variable to fix comma issue
FORCE_DECIMAL_GERBER_OUTPUT
true
Best Regards,
Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
Kudos are much appreciated if the information I have shared is helpful to you and/or others.
Message 3 of 8
PinRudolf
Thank you kindly Jorge! That sounds much better! I'm going to check this out, first I need to learn how to set environment variables. 🙂
Message 4 of 8
xpuipc
Hi @jorge_garcia,
where can i change this variable?
Thank you
Torsten
Message 5 of 8
PinRudolf
This works great Jorge! Thank you kindly.
Here's a quick instruction how to set environment variables:
https://www.architectryan.com/2018/08/31/how-to-change-environment-variables-on-windows-10/
Message 6 of 8
PinRudolf
Hi @jorge_garcia ,
This issue seems to be solved with the latest update? The update description does not mention it but I can no longer reproduce the error. Can you confirm this?
Thank you kindly!
Message 7 of 8
jorge_garcia
Hi @PinRudolf ,
I hope you're doing well. I know something was coming in this update to help with the CAM and polygon output. I'll confirm but I think the devs fixed it.
I'll repost once I have it confirmed.
Best Regards,
Jorge Garcia
Message 8 of 8
PinRudolf
Much appreciated Jorge! You guys are the best!
