Message 1 of 12
Replace Part Not Working Consistently
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Having issues trying to replace a part. Workflow is: right-click > replace > select new part from library.
The part is just a through-hole pad. There are 2 of these parts in the design.
I tried modifying the footprint of the existing part, then saved it to the same library. Using the above workflow the part would not replace. I received a message at bottom right informing me that the part was successfully replaced, but the footprint in the design was unchanged.
Instead I created a new part which uses the existing symbol but has a newly created footprint. Using the new part, I was able to change 1 part, but the 2nd part will not change. Each time I receive a message saying part was successfully changed, as shown in image below.
