Move between sheets
Move between sheets
jamieMY2Z5
Move between sheets
jamieMY2Z5
In the schematic editor, I can't seem to move components between sheets any more. It used to work just fine with the 'move group' command, but since they removed that command it doesn't work. Copy/paste is not a solution as it creates a new component (no good if for example I need to place opamp power pins on a different sheet to the rest of the opamp symbols). Is there a workaround?
jamieMY2Z5
I should mention that I have now found a workaround for IC power pins etc, by invoking from the command line in the new sheet. This doesn't solve the problem if I want to move an actual group of components and nets to another sheet though. Hopefully Autodesk fix this soon.
jorge_garcia
Hello @jamieMY2Z5 ,
There was a regression in this last release of Fusion. There is a temporary workaround but it should be resolved in the next release of Fusion.
So basically it's the normal work process but when you get the to the new sheet just activate the MOVE command and the components you were trying to move will show up on your mouse cursor.
Best Regards,
​Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
lauri_barnhart
Welcome to the community, @jamieMY2Z5.
Thank you for posting your question. Following up to see if the information provided by jorge_garcia clarified your question. If it did, please consider clicking on the 'Accept Solution' button.
Best,
Let us know how we did on Trustpilot.
Lauri | Community Manager
