refused odb++ datas
refused odb++ datas
a_bernhard4SNP3
refused odb++ datas
a_bernhard4SNP3
I tried to send our production data set with odb++ to our ems-manufacturer.
Unfortunatly he cannot import our odb++ data into his system. He told me the component layer is missing.
I took a look with odb++ viewer from Valor. There are all information about components and pads.
Here a screenshot of the Comp_+_top layer in text format
Can anyone say if there is a problem?
Best Regards
Andreas.
jorge_garcia
Hello @a_bernhard4SNP3 ,
I hope you're doing well. Would you be able to share your files both the design and the ODB++ files? They will never leave Autodesk and they will only be used for development and debugging.
Let me know if there's anything else I can do for you.
Best Regards,
Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
Kudos are much appreciated if the information I have shared is helpful to you and/or others.
a_bernhard4SNP3
I sent you a PN.
lauri_barnhart
Hi @a_bernhard4SNP3,
I wanted to check in and see if you still needed assistance, or if you found a solution to your question already? Let us know if you need further assistance by providing an update or if you have found a solution, please share it with the community so other members who may have the same question could learn from your experience.
All the best,
Lauri | Community Manager
