Push to 3D places part in the incorrect orientation
shawn3WMTV
shawn3WMTV
I am working on a PCB and was conststantly pushing to 3D along the way. Everything was going great until I added another two connectors. For some reason the foorprint was brought into the 2D pcb correctly but the 3D package is rotaged 180 degrees for some reason.
Anyone know what would possible cause this?
jorge_garcia
Hello @shawn3WMTV,
Thanks for reporting the issue. @yqliu I believe this has been reported before, but I don't remember the fix. If you do remember could you post it here?
Let me know if there's anything else I can do for you.
Best Regards,
Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
Kudos are much appreciated if the information I have shared is helpful to you and/or others.
yqliu
@jorge_garcia , yes we fixed similar issues before in code. This one looks different.
@shawn3WMTV , could you please check/try a few things? First, Could you also check the versions of the library, footprint and 3d model? If the version are all ok, please create a new design, place this part into the new design and push to 3D, will you get correct transformation?
shawn3WMTV
The library looks fine. The 3D view in the library has the 3D part in the correct orientation
I just re-created the same issue
Created a new electronic design
Added two of the connectors.
Pushed to 2D
moved them on the PCB
Pushed to 3D
Everything looked fine.
Went back to schematic and added a third connector
Went to PCB and moved it on the board.
Pushed to 3D, the original two parts remained correct, the new one is rotated 180 degrees.
This such a strange issue. I would start the PCB from scatch again but if I ever add a new connector the same issue is going to happen again.
shawn3WMTV
I found a work around. Which is itself a little odd.
I found that if a performed these steps
Push to 3D, in the Components options, turned all the components off.
3D pcb shows all footprint, no packages
Go back to 2D and push to 3D again, this time enable all components
3D PCB now has all components facing the correct directions.
However, if I performed these steps
Push to 3D, in the Components options, turn off only the connectors facing the wrong way
3D pcb only shows footprint for components I turned off
Go back to 2D and push to 3D again, enable all components
3D PCB still incorrectly places packages (180 off) for affected components.
Shawn
panpan_fan
Hi @shawn3WMTV
Thanks for reporting this issue to us!
It is a known issue and has been reported to the develop build.
And I will keep you updated when we release the fixing for this issue.
YOur workaround is correct - - push to 3d by uncheck all instances related to the rotated package and then push again with all instances checked.
Before the fixing, please use the workaround to avoid this issue.
Sorry for all inconvenience.
Panpan Fan
HelenChen-AutodeskQA
Hi @shawn3WMTV ,
Hope all is well.
Much appreciated for reporting this issue to us ago.
Good news that we have put a fix about it in the latest Fusion build 2.0.19725 which was live yesterday.
Could you please upgrade to the latest version to have a check? Hope it helps.
Please feel free to let us know if you need further assistant.
Thank you.
Best regards,
Helen
Helen Chen
Principle QA for AutoCAD Windows
