I want to make two copper pours, one smaller copper pour is inside the larger copper pour.
They have the same net. I want them to be separated from each other such I will decide where to connect the two pours (via thick route).
What I want to do is something like in image below. I was able to generate that view by assigning a dummy name for the smaller copper pour net (like xyz) then return the net name to the actual name (DC_GND which is same as larger copper pour). However, generating gerber results to continuous ground pour, even if I set rank 1 on smaller copper and rank 2 on larger copper.
