Project settings/attributes for ULP across schematic and PCB
drew3L45Q
drew3L45Q
Is it possible to access project wide (global) setting or attributes from a ULP across a schematic and board?
We would like to have data for the project such as project name, revision, release, etc available via ULP in both the schematic and the board. Based on the ULP documentation there does not seem to be a 'project' object. It also looks like you can't reference a Schematic from a Board, or a Board from a Schematic.
RichardHammerl
Hi @drew3L45Q ,
thank you for the ULP question. I have to admitt I am not an expert in ULP programming, but I looked into some of the ULPs that come with Fusion. In one of them I found a "project" object and it is used like this:
I hope this helps.
Best regards,
Richard Hammerl
