PCB Edge connectors library
kerger.marc
kerger.marc
HI
I am new to the PCB layout process, I see there are tons of libraries, but I can't find one with edge connectors for PCB. does anyone know a library with those? ideally 2,54 pitch.
thanks
panpan_fan
Hi
I hope you are doing well!
You can find the connectors in Connector library.
Please check if it has the components you want.
Panpan Fan
kerger.marc
Thank you but I am looking for a different connector,
like this one:( but more pins)
alfonsotames7AURA
Me too
m.neujahr_at_moe
Hello@kerger.marc , @alfonsotames7AURA ,
there seems to be no library with your connector.
Do you have a datasheet or link with 3D-data?
If you have it, it's very easy to make it by your own:
  • Make your own library called "my-con"
  • Copy a similar device (pin-count should be the same, footprint can be a little different)
  • Adjust the footprint
  • Add 3D-Data to your footprint
  • Save your library
If you download Eagle and extract it, you will find in the program-subfolder a realy good documentation:
Chapter 8: Component Design Explained through Examples in "manual_xx.pdf" is a good starting point
Eagle 9.6.2 / Fusion 360
Working with Eagle since Version 3.x
