New user trying to create a round polygon pour
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I am trying to build a custom PCB and the learning curve is quite steep. I am pretty confident in the standard 360, but Electronics is much more difficult for me to get my head around. I have the board built (its a basic board) but I have to create some tracks for a potentiometer wiper to run around and I am struggling to do this.
The board is roughly 40mm x 40mm with a 6mm hole in the middle. I am trying to create a solid ring ground plane in the middle for the ground wiper and a segmented ring on the outside that I can connect to each of my pads on the outside of that (this is a stepped attenuator) with as small a gap between each segment as possible.
I tried to use the board shape circle option to create the outer edges of the rings, but then I couldn't select them to execute the polygon pour. Nor can I figure out how to pour a round polygon.
Loads of googling isn't helping much either. Clearly my limited knowledge is blocking me on these final steps.
I have attached a mock up of what I am trying to do in Fusion 360. I assume if I can create these tracks, I am drop a small pad inside of them that is in my schematic to clink them to the components?
