Module naming help
Module naming help
robert.martinUKYP4
Module naming help
robert.martinUKYP4
I am currently doing a schematic with modules but have completely forgotten how to renumber parts using the offset. I.E. R101 instead of POWERSUPPLY1:R1 I vaguely recall it being done with a ULP but I can't remember what it was and I can't seem to find any documentation of this specific problem.
Could someone please point me in the right direction or at the very least, to an example of it being done somewhere.
RichardHammerl
Hi @robert.martinUKYP4 ,
please check the properties for the module instances in your schematic. There is a parameter named "Offset".
Best regards,
Richard Hammerl
robert.martinUKYP4
Hi Richard,
Whilst I can see the offset dropdown, whatever I select is not persistent after I deselct the module. Whenever I go back to select, the offset is always 0
Cynthia.MacLeod
Did you ever get this to work as I am seeing the same behaviour (offset always resets to 0)
Cynthia.MacLeod
Actually - I did get it to work. Looks like this is a bug in the inspector where it doesn't write the value even though you can change it.
You have to right click the module instance itself, select properties, and change it in the dialog box, and click OK (or apply) for it to actually take effect.
jorge_garcia
Hello @Cynthia.MacLeod,
Thanks for reporting this. I've filed a bug report for this issue.
Let me know if there's anything else I can do for you.
Best Regards,
​Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
Kudos are much appreciated if the information I have shared is helpful to you and/or others.
panpan_fan
Hi @Cynthia.MacLeod
I hope you are doing well!
Today we release Fusion V2.0.20256 and we the offset issue should be fixed now.
Please upgrade Fusion and have a try, thanks!
Panpan Fan
