Issues with 3D PCB solder mask
erik.hole
Message 1 of 13
erik.hole
I have this error where the soldermask of the 3D PCB view of my design. Also. The soldermask is selected in the design to be white with black silk screen, but shows up as black in the 3D pcb viewer. Though in the cam processor preview it's the correct color.
Cam processor previewCam processor preview
F360 Solder Mask errorF360 Solder Mask error
Replies (12)
Message 2 of 13
yqliu
Hi @erik.hole ,
It looks like the solder mask wasn't built correctly. Is it ok to share your pcb file to me so that we can look into the issue? my email is [email protected]
Message 3 of 13
yqliu
Hello @erik.hole ,
I confirmed that there is a bug about the color. Before we fix it, please assign the color/material manually in 3D PCB environment. Actually this provides more control to the appearance of the board than the settings in cam preview dialog:
Message 4 of 13
erik.hole
Ok, thanks for the work around!
Message 5 of 13
ImDaveM
I am having the exact same problem,
So I did the suggested work around, I got the colours/appearance i wanted.
BUT..
I made a small change to the SILKSCREEN text in the BRD editor, and all the manually modified colours no go back to the errors, i.e white silk appears Black!
When are you going to fix this. I have just updated with today's update and the problem is still there!
thanks
Message 6 of 13
yqliu
@ImDaveM,
We missed the timeline to include the fix into the latest update. The issue will be fixed in the next release.
Message 7 of 13
ImDaveM
OK, fair enough.
while your at it, can you fix up the hierarchy of components in the browser tree for 3D PCB's?
You have the BOARD Component which has the PCB & the canvases,
but, straight underneath you have 4 components ( foa 2 layer board) that are part of the BOARD component but are in level one of the "BOM" tree this is wrong, the copper Layers and Solder mask "components" should be under and indented from the BOARD Component.
Message 8 of 13
yqliu
This is done on purpose to simplify the hierarchy. Do you see any issues to work with the current structure?
Message 9 of 13
keqingsong
Hey all - this issue now be fixed in our latest Jan 2021 product update!
Keqing Song
Autodesk Fusion Community Manager
Portland, Oregon, USA
Become an Autodesk Fusion Insider
Message 10 of 13
erik.hole
I updated F360 Today, deleted the linked 3D PCB and pushed it again. The issue persists.with soldermask.png
Message 11 of 13
erik.hole
I tried to set the color to white on the soldermask as well, and the soldermask just dissapaired. This is in a completely new design
Message 12 of 13
AutomaticRock
I have the same experience. This issue has not been resolved in the last update it seems.
At least the work-around still works..
Message 13 of 13
erik.hole
Sure, there's always that. Though it seems to me that there's not too much testing of features and fixes going on when this is what they call a bug fix, as well as temporarely removing hotkeys for saving and so on on new versions. The "keeping everyone on the same version" is a great thing if one have the right amount of development resources available, but at least from the outside view it seems like the development team on F360E is too small when they depend this much on live testing.
