Duplicate device by Comand Line / Script;
Kristey
Kristey
I'm trying duplicate a devise by command line or script with a diferente name.
R ->duplicate->(new)R_22R00
I try Copy -> Past commands, but this don't work.
COPY 'R';
PASTE 'R_22R00';
How I can make this?
jorge_garcia
Hi @Kristey,
I hope you're doing well. It looks like the duplication command is still not exposed in the CLI. I'll ping the developers just to be sure, but I think this is the case.
Let me know if there's anything else I can do for you.
Best Regards,
Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
Kristey
Is it possible to implement?
Is it possible by ULP?
I'm struggling a lot with the workflow of components and libraries.
The workflow is a bit confusing and the functionality does not work in the same way as Eagle and Fusion.
For example, "technologies" are not manipulable in fusion360 (at least I haven't found how).
I wanted to create clean libraries and with my codes to export a BOM that is clean and easy to integrate into our system. But it’s not easy to get a good workflow.
Kristey
In fact it is possible.
After open library if you write "COPY devicename.dev@libraryname newdevicename" works.
