IPC-D-356 ULP Issues
al_walker
Message 1 of 10
al_walker
I have been using the ULP macro ipc-d-356 to create IPC-D-356 netlists, however a major PCB vendor (IPC-accredited) has advised me that the netlists produced by the ULP do not comply with the IPC standard.
Two issues reported:
  • Each record should use the 80-column ASCII character format
  • For no connects, characters 4-6 should be 'N/C' whereas the ULP uses code 327 with characters 4-6 blank
Is there another existing method in Fusion Electronics to generate netlists that comply with the IPC-D-356 specification please? If not can I ask that the existing ULP is reviewed and updated to comply please?
Kind Regards,
Al
Replies (9)
Message 2 of 10
jorge_garcia
Hello @al_walker ,
I hope you're doing well. There is no other mechanism for generating IPC-D-356 netlists. I'll create an enhancement request for this.
With that said, I worked on this ULP at one point and one thing you have to be careful with and long netnames. Because you only have 80 characters and certain characters have to be in certain places. With current ULP long net names are not handled properly and that causes the output to break format.
Let me know if there's anything else I can do for you.
Best Regards,
Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
Kudos are much appreciated if the information I have shared is helpful to you and/or others.
Message 3 of 10
al_walker
HI @jorge_garcia
Yes, I'm aware of the 14 character limit for net names. In this case it's rather more how No Connects are handled that is being reported as the issue.
Feedback from the PCB vendor:
"For the netlist issue, we checked the IPC file generated by other EAD software, its 4th-6th characters N/C represent single point net/isolated point, while it seems, 327+blank in IPC file you provided, represent single point net/isolated point. So to avoid mistake, please generate and provide IPC file in the standard format, there should be 80 characters for each record.Thanks."
Kind regards,
Al
Message 4 of 10
lauri_barnhart
Hi @al_walker,
I wanted to check in and see if you still needed assistance, or if you found a solution to your question already? Let us know if you need further assistance by providing an update or if you have found a solution, please share it with the community so other members who may have the same question could learn from your experience.
All the best,
Lauri | Community Manager
Message 5 of 10
al_walker
Hi @lauri_barnhart
Thanks for reaching out, I'm still waiting on a response on the No Connects issue.
Kind regards,
Al
Message 6 of 10
jorge_garcia
Hello @al_walker ,
I hope you're well. I reported this issue and that's about as far as I can take it. There's no guarantee that a fix can be done quickly to the ULP. Options now are to manually try to fix the ULP or modify the output file.
Best Regards,
Jorge Garcia
Message 7 of 10
al_walker
Hi @jorge_garcia
I understand that you can only report issues, but could you confirm one thing for me please?
It looks like the netlists produced by the ULP do not conform to the IPC-D-356B standard, dated 2002.
For instance, per section 5.1 Organization of the Job Data File the header does not contain the following parameters in sequence:
JOB
VER
SOURCE
CODE
TITLE
NUM
REV
etc.
And per section 8.2.1  the absence of 327N/C for No Connects
Could you confirm which version of IPC-D-356 that the netlists generated by the ULP are compliant with please?
Kind regards,
Al
Message 8 of 10
jorge_garcia
Hi @al_walker ,
The initial release of the ULP was in 2003, but it's unlikely that the IPC-D-356B standard as used. The ULP makes no mention of the version used in the code but I would expect it to be the version prior which is IPC-D-356A.
Best Regards,
Jorge Garcia
Message 9 of 10
al_walker
Hi @jorge_garcia
Thanks very much, can I suggest that after 20+ years that we're overdue an update to IPC-D-356B please?
Kind regards,
Al
Message 10 of 10
jorge_garcia
Hi @al_walker ,
The ticket is already there, it's just a matter of getting it implemented.
Best Regards,
Jorge Garcia
