Improve running time of scripts?
benL9LDN
benL9LDN
New to Fusion 360 (long-time Eagle user), I'm attempting to use some scripts we've developed for doing LED matrices in Fusion 360.  While the scripts are actually executing just fine, they are running incredibly slowly.  It appears that the "command helper windows" are being animated even while a script is executing, and this is perhaps slowing things down significantly.
The board script was a good bit slower than the schematic script, but both took a while.
Here is video of the script in action: https://twitter.com/BenPeoplesInd/status/1243251969990459400
It took a total of 30 minutes to run this script, which consists of 3441 commands, so took about half a second to execute each command (on average).
Here's a few excerpts (proprietary, so I'd like to not post the whole script):
MOVE LED18 (68.0 0.0);
MOVE LED19 (72.0 0.0);
MOVE LED20 (72.0 4.0);
ROTATE R180 LED20;
MOVE LED21 (68.0 4.0);
ROTATE R180 LED21;
MOVE LED22 (64.0 4.0);
ROTATE R180 LED22;
SET WIRE_BEND 2;
WIRE 0.4 (2.9 19.35) (2.9 18.35) (6.9 18.35) (6.9 19.35);
WIRE 0.4 (5.1 20.65) (5.1 21.65) (9.1 21.65) (9.1 20.65);
WIRE 0.2 (5.1 19.35) (6.9 20.65);
SET WIRE_BEND 2;
VIA 0.2 Round (34.9 90.35)
VIA 0.2 Round (37.1 93.65)
In AutoCAD, there's always been a way to call the "plain command" with an underscore before the command and avoid all the UI goodness.   There doesn't seem to be a similar functionality in Fusion 360.
Any solutions here, or do we just need to schedule a coffee break before running scripts?
jorge_garcia
Hello @benL9LDN,
I've passed this along to our developers for review. Let me know if there's anything else I can do for you.
Best Regards,
Jorge Garcia
​Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
Kudos are much appreciated if the information I have shared is helpful to you and/or others.
benL9LDN
Thanks Jorge!
If they want to reach out directly, I'm happy to supply complete scripts for testing.
-- Ben
HelenChen-AutodeskQA
Hello @benL9LDN ,
Hope all is well.
We just released new Fusion 360 version 2.0.8560 today which includes the fix for the issue you reported.
Could you please upgrade Fusion 360 and have a try?
Hope it works and thank you very much for reporting it to us.
Helen
Helen Chen
Principle QA for AutoCAD Windows
