- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Probably inadvertently, a feature which is very importat to me has been removed in the latest update: it is now impossible to change the signal that a net or a via is associated with.
Suppose, like in the following example, that a PCB contains two identical sections (two motor drivers here). Routing the same stuff twice is very tedious, so I've always followed this procedure:
- Arrange the components of the fist "block" as necessary
- Use the "Copy format" tool to copy the coordinates of each component in the first block and apply them to the components of the second block
- In the case of the two blocks aligned vertically, I start by copying only the X coordinate
- Then, I move the entire second block to the side of the first one, and transfer the Y coordinate of every component
- I finally move the second block back to its original position
- Route the first section with wires, vias and polygons
- Using the selection filter, copy only wires, vias and polygons from the first block and paste them on the second block
- Change the signals associated to the newly copied wires, vias and polygons, either using the "Name" command or by changing the signal name from the object's properties
The last step has now become impossible because the latest update changes the behaviour of the "Name" command in the PCB environment. Previously, the "Name" command, when executed from the PCB, would only change the signal associated with an object (e.g. a wire associated with SIGNAL_1 becomes associated with GND, and not anymore with SIGNAL_1).
Since the latest update, the "Name" command renames the signal associated with an object, e.g. SIGNAL_1 is renamed to GND. This has following bad side effects:
- The command fails every time SIGNAL_1 was also connected to something else, because Fusion tries to merge SIGNAL_1 and GND, returning an error (see picture below).
- If, instead, I use the "Name" command to rename SIGNAL_1 to NEW_SIGNAL, and NEW_SIGNAL isn't already connected to something else, the schematic is modified from the PCB environment, i.e. back-annotated, which is very undesirable. No change on the PCB should ever modify the schematic!
The same is also true when changing an object's signal name from its properties.
Please, bring back the previous behaviour. I can't see a use case for the new behaviour (renaming signals from the PCB environment, why?), and back-annotating the schematic is a very bad thing.
I am available to send example projects and discuss the issue further via email.
Marco Cipriani
