Implementation of polygon properties has changed
matthewM5M9D
Message 1 of 8
matthewM5M9D
I saved a new copy of my design and made some changes.  However, some polygons have changed in an area of the board I haven't touched.  I made no changes to any polygon properties.
see pic areas highlighted in blue
ORIGINAL POLYGONS in previous design
NEW POLYGONS in updated design
Why are the polygons no longer connecting?  Their properties are identical in previous and new versions.
Replies (7)
Message 2 of 8
jorge_garcia
Hi @matthewM5M9D ,
I hope you're doing well. Did you make any changes to your rules? It's really difficult to establish that the design hasn't changed enough for this to happen. Rules changes like copper clearance changes could cause thermals not to fill.
Review your design rules and see if that could explain the change in the thermal fill.
Best Regards,
​Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
Kudos are much appreciated if the information I have shared is helpful to you and/or others.
Message 3 of 8
matthewM5M9D
The properties of the 2, top copper polygons (GND & V_CMD) are unchanged.  No design rules changes were made.
Properties of previous, OK polygons
Properties of new, NOT OK polygons
As you can see above, the polygon properties are the same for respective polygons in previous and new copy of design.
Design Rules
OK Polygons, previous design
 NOT OK Polygons, new copy of design
The design rules are identical.  There are no custom rules.
Just to reiterate, I saved a copy of an existing design and changed components in a different area of the board.  I made no changes to Design Rules or the properties of these 2 polygons (V_CMD, GND [both top copper polys]).  I only became aware of an issue when I checked design rules.
The only polygon I changed was a GND poly on the bottom layer.  I reduced the isolation property to ensure the ground pins of an IC connected to the poly (I posted about that here, https://forums.autodesk.com/t5/fusion-electronics-forum/only-some-gnd-pins-connect-to-gnd-polygon/td...
I'm missing something, probably obvious!
Message 4 of 8
jorge_garcia
Hello @matthewM5M9D ,
I hope you're doing well. Would you be willing to share the files for review? That way we can get to the bottom of this.
I'll DM you my email.
Let me know if there's anything else I can do for you.
Best Regards,
​Jorge Garcia
Message 5 of 8
jorge_garcia
Hi @matthewM5M9D ,
I hope you're doing well. I have opened your files in my install of the latest release of Fusion without modifying the files at all and the polygons are back to looking OK.
​Jorge Garcia
Message 6 of 8
matthewM5M9D
Your image shows the issue 3 board.  The problem appears on the issue 4 board.
On the issue 4 board there are 2 polygons (GND & V_CMD) which no longer make contact with 2 pins (as shown in earlier images).  For the issue 4 board I instead have routed 2 wires to make the connections.
Message 7 of 8
jorge_garcia
Hi @matthewM5M9D ,
I hope you're doing well. So if you unfill and refill 3, you'll see that the polygon recalculates to not have the thermals. I know for this release we had to fix a major thermal bug and this seems to have the unintented consequence you are seeing on these boards. I'll create a ticket for this and share it with the developers.
Best Regards,
​Jorge Garcia
Message 8 of 8
matthewM5M9D
Ok thank you.  Yes when I hide then show polygons in Iss 3, the thermals disappear and do not return, as you say.
