How do I get the previous layer 35 (with Eagle) tGlu or bGlue in a library?
infoJFAS4
infoJFAS4
Hello everyone,
In order to convert a circuit board from reflow to wave soldering, you have to enter the adhesive dots in a layer for some parts in the library in order to be able to have an adhesive template made from them.
At Eagle it was always very easy. I drew the glue points in the footprints in the libraries and then took layer 35 or 36 into account when creating the Gerber. Everything was good.
With Fusion there are no layers 35 and 36 when I open a corresponding footprint in the library. At least I haven't found anything how to show them.
You can create your own layers starting at number 100, but that only helps me to a limited extent. In these layers from 100 onwards I have stored information for milling contours for front panels and other things in my own libraries.
In order to be able to create sensible CAM jobs in the future, the standard layers 35 and 36 should be available.
How do I get layers 35 (Eagle: tGlue) and 36 (Eagle: bGlue) back?
Greetings Peter
Pieter.Jan.Van.de.Maele
I just checked and saw these are no longer defined by default which is a significant issue. Thanks for reporting this!
To get them back you can use the command line:
layer 35 GlueTop
layer 36 GlueBottom
Hope that helps, we will get this resolved asap!
Pieter-Jan Van de Maele
Senior Engineering Manager, Fusion Electronics
infoJFAS4
Thank you for your quick help.
HelenChen-AutodeskQA
Hi @infoJFAS4 ,
Hope all is well.
Much appreciated for reporting this issue to us ago.
Good news that we have put a fix about it to bring those layers back in the latest Fusion build 2.0.19725 which was live yesterday.
Could you please upgrade to the latest version to have a check?
Please feel free to let us know if you need further assistant.
Thank you.
Best regards,
Helen
Helen Chen
Principle QA for Fusion 360 Electronics
